Not every user has a graphic environment with a mouse or other pointing device. Some users rely on a keyboard, or voice input to navigate links and activate forms. To support such users as much as possible this website supports a technical standard called Access Keys - essentially this is a way to define keyboard shortcuts that allow you to navigate to sections of the site without using the mouse.
Simply press the F12 key and press either the Tab or Tab+shift keys to navigate to your desired menu option. The drop down menu in the menu bar will not drop down but you will be able to navigate the sub-options - the different options will be listed in the status bar of your browser as subsequent key presses cycle through them.
Regulated by the ICAEW
© Jon Child & Co. All rights reserved. legal information |
accessibility
Email: enquiries
VAT Registration Number: 911 6650 40
